Tech Tip: Using Regular Expressions and Field Masks with Laserfiche Forms
< 1 min read
  • Information Technology
By: Eric Cressey
Technical Writer
As you create forms in Laserfiche Forms, you’ll often use single line fields to capture information like the user’s name, Social Security number, phone number, and more. This information often has formatting requirements that users must conform to.
You can use regular expressions to ensure users fill these fields with properly formatted values. For example, the regular expression you’d use for a Social Security number’s XXX-XX-XXXX format is:
ddd-dd-dddd
A single line field using this regular expression would only accept values in this format.
By themselves, regular expressions do not offer insight into the format the field requires. To inform users of the required formatting, you could use helpful text above the field, but users would still have to manually add the necessary dashes, parenthesis, and other formatting.
Field masks, which apply visible formatting to values as a user enters them, are a way to make entering properly formatted information as easy as possible. If you’ve ever entered your phone number in a field and seen the parenthesis and dashes appear automatically, you’ve seen a field mask at work.
Using regular expressions and field masks makes it easier for your users to enter information and ensures that you will capture data in a consistent format.
See more regular expression examples in Forms.
Learn more about using regular expressions with field masks in Forms.
Watch a 2-Minute Demo
WATCH A DEMO
Take a Product Tour
PRODUCT TOUR
Related Blogs
New SME Market Research Reveals Manufacturing Leaders’ Priorities in the Next Investment of Digital Transformation
Five Things I Wish Everyone Knew Before Migrating to Cloud
Intelligent Automation in Healthcare: What Motivates Investments in the Next Generation of EHR Integrations
What Is Vendor Sprawl? And How You Can Solve It.
Top Use Cases for Intelligent Content Capture
